Oh, good. ;) So, one of the ones right under the head then, right? I'll pull it apart tomorrow. It was the hose right at the head that popped (literally made a popping sound when it ripped open). I wonder if the ktms use the same orings... Thanks!
Riding 3/17 plus a really hot bike
Re: Riding 3/17 plus a really hot bike
Looks like the ktm o-rings will work. Will pull it apart first then head to JT tomorrow...
KTM 2016 300 o-rings:
0770078020
0770105020
0770078020
0770105020
As much as it pains me to say this, the KTM o- rings are the way to go for replacements.Marylander wrote: ↑Thu Apr 04, 2019 7:53 pm Looks like the ktm o-rings will work. Will pull it apart first then head to JT tomorrow...
0770078020
0770105020
So your bike is really a KTM. Please don’t tell Skinny-JWingfixer wrote: ↑Thu Apr 04, 2019 10:20 pmAs much as it pains me to say this, the KTM o- rings are the way to go for replacements.Marylander wrote: ↑Thu Apr 04, 2019 7:53 pm Looks like the ktm o-rings will work. Will pull it apart first then head to JT tomorrow...
0770078020
0770105020
2019 Husqvarna TE250i
2014 KTM 350 XCF-W Six Days
2012 GASGAS 280 TXT Racing
Yeah, apparently the 2 stroke engine designers bounce around between manufacturers as needed and keep some things at the same spec for all of them. So most, if not all, of the euro brands have engines with strong similarities.trialsrider wrote: ↑Fri Apr 05, 2019 2:55 amSo your bike is really a KTM. Please don’t tell Skinny-JWingfixer wrote: ↑Thu Apr 04, 2019 10:20 pmAs much as it pains me to say this, the KTM o- rings are the way to go for replacements.Marylander wrote: ↑Thu Apr 04, 2019 7:53 pm Looks like the ktm o-rings will work. Will pull it apart first then head to JT tomorrow...
0770078020
0770105020
The piston and cylinder still look like new, a scathing condemnation of my lack of riding in the last couple years... I had thought I would use the stock computer to track use but its been less reliable than I would like. I should get an hour meter when I'm at JT.
The bike is all back together. I replaced the CF skid plate with an EE AL one; prettied the bike back up (silly, I know); swapped in a shinko mx216 90/90 front tire/added tubliss; repacked the silencer; mounted a new gnarly pipe; put on some samco hoses/clamps (eliminating the thermostat); went to a richer needle and main jet; and probably other stuff.
I balanced the front wheel and it took a buttload of weight. I had just thrown a couple of the big weights on before since the front wheel was wanting to hop while going down the road but this time I actually put it on the balancer.
Looks great. What is the piece over the air filter cover?
