Being only 12’ wide you should have no worries about walls spreading with collar ties if held down a third or half way with a 8/12 pitch. If you insulate floor use only ridged foam, mice love anything else and you won’t be able to stand the smell. Did you price a shed?
2012 Husky WR 125
2009 Husky TE 310
2001 Harley FLHR
2009 Husky TE 310
2001 Harley FLHR
Taylor wrote: ↑Fri Sep 28, 2018 8:43 am Being only 12’ wide you should have no worries about walls spreading with collar ties if held down a third or half way with a 8/12 pitch. If you insulate floor use only ridged foam, mice love anything else and you won’t be able to stand the smell. Did you price a shed?
I can build it for half the price that I can buy one. And I can buy the wood when I have the $$. Almost like making payments.
Also, the "Amish" sheds are nice. But the materials are a little "light".
Sea containers make a secure base to start with. Lots of options what you can do and they can be had for cheap. (2) 20' units give you a 16 x 20 area. The 40' units normally can be had for less than the 20' units as they have become popular for construction storage.
I did consider containers. SWMBO said no She has no vision
But access is also an issue.
Since my riding plans got screwed up, I started on this. Spent most of my time getting it level and square.
Where is your permit?
floor joists spacing looks a smidge wide
16" oc when I'm done. I ran out of nails,
Progress.
