On the Montesa trials hack, I was missing the left footpeg. That is where the hack attaches. Since I'm converting it (temporarily) back to a solo bike, I needed a left footpeg. Boom Boom also said I needed to get a wider set.
Most people cut off the mounting lug and weld on a new mounting point that allows the use of modern pegs. I didn't want to do that because I'd then need to modify the sidecar. It seemed much easier to modify a set of stock pegs and I had a set of older KTM pegs in the parts box.
In the picture below, the original peg is on the left and my modified KTM peg is on the right.
Okay I'm a cheap bastard but hey! I'm laid off, what else did you want me to do?
Vintage Trials Footpegs
Re: Vintage Trials Footpegs
You are going to be a much happier camper with those bigger pegs.
I trust you cuz I sure won't know the difference!Boom Boom wrote:You are going to be a much happier camper with those bigger pegs.
can't wait for the last parts to show up. Since I have a lot of time off right now, I want to ride it!
we need to setup a trials course in your back yard. Caleb can ride his Oset and we can take turns on the Montesa.Bucho wrote:Looks good!
