I Blew A Seal
I Blew A Seal
Fork seal. Either I rode it too hard in the Barrens or what they say about cinching the front down too tight is true.
Re: I Blew A Seal
it could have a speck of dirt in there, you can use a small screwdriver on the outter edge of the outtermost seal, usually called a wiper. Then get some roll off film and slip it up pass the seal and fork tube then pull it out while rotating around the tube, many times i saved a leaking seal.
Re: I Blew A Seal
blew a seal? would that be Ring or Harp?
Re: I Blew A Seal
Kyler wrote:blew a seal? would that be Ring or Harp?
Hey what Jeff does on his own time....................
Re: I Blew A Seal
A couple of ratchet straps around the swing arm, near the rear axle will really stabilize the bike and allow you to not have to crank the front down so hard.jxs2151 wrote:Fork seal. Either I rode it too hard in the Barrens or what they say about cinching the front down too tight is true.
Re: I Blew A Seal
are you sure it wasnt that fish sandwich you had for lunch? oh and the myth about strapping the bike down to tight is bull shit
2002 XR650R (plated)
1990 TransAlp
2000 XR650R (trophy)
2002 CR125R
2009 Big Red
1977 CT90
2008 CRF230L (wifeys)
2003 XR650R (crackbabys)
1999 CR80R (crackbabys)
1972 XL250 (crackbabys)
1990 TransAlp
2002 CR125R
2009 Big Red
1977 CT90
Re: I Blew A Seal
X2 on the film idea. Providing that you don't have a mark on the fork tube that damaged the seal, dirt in the seal is the most likely suspect. For film, I use the plastic sheets from our office laminating machine.Hare wrote:it could have a speck of dirt in there, you can use a small screwdriver on the outter edge of the outtermost seal, usually called a wiper. Then get some roll off film and slip it up pass the seal and fork tube then pull it out while rotating around the tube, many times i saved a leaking seal.
530 XCR-W...plated
300 XC
WR450
XR600R...for sale
300 XC
WR450
XR600R...for sale
Re: I Blew A Seal
What are you guys talking about dirt and screwdrivers?
I was merely commenting on my deviant oral sexual behavior with pinnipeds.
Seriously, thanks for the advice. I'm gonna look into the suggestions.
Re: I Blew A Seal
Reminds me of an old joke.
A penguin was driving down the street, and noticed a horrible cloud of smoke behind his car, so he pulled into a mechanic's garage.
The mechanic says "It'll be about an hour for me to figure out what's wrong." So, the penguin goes to the diner across the street and eats lunch.
An hour later, he comes back and the mechanic says "It looks like you just blew a seal." The penguin says "Oh, it's just ice cream."
Re: I Blew A Seal
I put a short piece of 4X4 between the tire and fender(between the forks), then ratchet the front.
