There is nothing left to overhaul...
Re: There is nothing left to overhaul...
If it's a sleeve, it's probably iron. Iron is generally not coated --- and I'm assuming you mean the newer nickasil-type coatings? If you did decide for whatever reason to get an aluminum liner and coat it, I'd ask your piston MFG if you'd need to get rings that are meant for a coated cylinder.
Wow. It's almost a new bike.
I've been reading on the CR500 forums that it is recommended to nickasil the iron liners and you essentially never have to bore it again - just change rings.Roadracer_Al wrote:If it's a sleeve, it's probably iron. Iron is generally not coated --- and I'm assuming you mean the newer nickasil-type coatings? If you did decide for whatever reason to get an aluminum liner and coat it, I'd ask your piston MFG if you'd need to get rings that are meant for a coated cylinder.
. Redo the head bearings, change the plastic and paint it and it will be!Roadracer_Al wrote:Wow. It's almost a new bike.
I look at it this way. Bucho and I shouldn't have any issues to work out after this other than how to improve our hack riding skills!
Not a bad idea, nikasil, especially since you will have a fresh bore, i will see if Pat has any hooks, he will have to fit and match the sleeve to the cylinder then send it and piston out to get plated and piston fitted, otherwise i am sure any of the big boys would do it np, find out who some quality vendors are.
We should make sure the honda pistons have pretty close tolerances.
R2 Performance does bore and plating (Florida) they rebuild cranks tooHare wrote:Not a bad idea, nikasil, especially since you will have a fresh bore, i will see if Pat has any hooks, he will have to fit and match the sleeve to the cylinder then send it and piston out to get plated and piston fitted, otherwise i am sure any of the big boys would do it np, find out who some quality vendors are.
http://www.r2performance.net/cr500.html
PowerSeal USA - north of Philly - does not do porting but will bore and plate
http://www.powersealusa.com/
Eric Gore is renowned for his CR500 work but doesn't do plating
http://www.eric-gorr.com/porting.html
ahh the joys of used bikes, well there are further set backs, time for re-direct, i will be brief.
Crankshaft shaft part is screwed as in no good bearing spun on it, and after some minor checking around, it seems crankshafts for 85-86 CR500 are rare at best. all the other years are the same except 85-86, yes it can be repaired but real quick we could get a bunch of $$$ in a crank that is obsolete.
To update the crank requires changing the cylinder to proper deck height, still will have to do the related work, port /relieve exhaust bridge etc. at this point we would be well on our way to $1K ($400. crank + $300 jug + $100. piston + labor) and we havent even replaced the main bearing etc yet, from all the excessive vibration the whole engine has a good bit of wear on it.
Not that it happens often but this time it may be a cheaper idea to find a whole CR500 engine thats a 87-02 and will bolt right in. Pat is seeing what he can come up with as far as cheap repair items and i have the feelers out for any CR500 engine parts.
If anybody has any hooks Kyler could use them! a decent 85-86 crank and a decent top end for the same year would be tight! otherwise a whole engine no matter what the year would work too.
I'm beginning to think Bucho and I are not 'sposed to be sidecar guys... this is very depressing
here's some on Craig's list - what do you think?
http://newlondon.craigslist.org/mcy/1362847156.html
http://sandiego.craigslist.org/esd/mcy/1389585031.html
http://boston.craigslist.org/sob/mcy/1388042052.html
I sure hope you can turn up a motor otherwise I'm done sidecar riding for a while
Okay - have found a crank and am negotiating
also found an 87 motor for $500 but it needs some clutch work.
Joe - give a holler! am thinking the 87 motor is a better bet.
this motor was in a EML MX sidecar. new Boyesen billet ignition covers are ~$80... 87 engine ... 91mm piston with pro-circuit port job. Has probably 10 hours on the piston. Top end, Bottom end and transmission are in great shape. It does have an issue with the clutch though. It will not disengage the clutch, maybe a broken spring or push rod? The clutch cover has been epoxied/repaired, also it has no Ignition cover. This is why I'm selling it for cheap, it needs a little work. Comes with CDI, Coil, Kicker, Shifter and a new clutch side cover gasket. (no carb)
after doing some more research i would try to find a 1990-2001 CR 500 engine for $500. - $600. depending on condition
for the rest of you following the Saga of the Black Hole Known as the Wasp...
Hare has some feelers out which may turn up a motor or crank locally. I've found some raplacement cranks but so far, they ain't cheap! The PO has a spare crank and he's checking to see what the condition is but I'm not hopeful.
Bottom line - the Wasp won't be running again anytime soon.
Users browsing this forum: No registered users and 24 guests
