it is $20 for a replacement plate - I just got oneDINGO wrote:Last time I was up at Granvilles, I lost my plate and holder somewhere in the woods (about a month ago). If anyone gets back up there before I do and comes across it, let me know. Not happy about giving MD another $100 for a plate.
Cracking tags
Re: Cracking tags
Re: Cracking tags
Yeah, I lost a tag at Greenridge this past January. Looked for it, but never found it.
Not that you really want to give the MVA anything, but $20 beats a hundred.
Re: Cracking tags
I'd say that a strip of rubber mouse pad material between the plate and the bracket would resolve that completely.
Re: Cracking tags
Well, I tried the cable ties for Michoux. The good news is, I didn't loose the tag. The bad news is, it still cracked. One corner cracked completely off, and the other is about to go too. This was the first ride with the new tag. I think next I'll try a four point mount to a thicker piece of metal with some rubber between the mount and tag.
Re: Cracking tags
I think four point mounting and support is going to be necessary for off roading. Kinda funny, but my tag takes the most abuse at Green Ridge because of the higher speeds and more g's.
An after market tail light and mini fender might work well. I have the Acebis LED on my DRZ and it has held up well. It is zip-tied to the sub frame, then the tag is zipped to it (I had to drill my own mounting holes). Check out this page for options:
http://www.acerbis.com/p107_headlight/p107.html
They are pretty cheap too.
Re: Cracking tags
i cut an old sign made of aluminum about an 1/8 inch thick and pop riveted it to the tag drilled hoes in the sign metal and had no problems, did this with the cracked tag cuz going to the mva-dmv whatever sucks
Re: Cracking tags
There you go, good solution. Pop rivet the tag to the tag holder an no pesky tag theft problems either.
Re: Cracking tags
The tag on the ktm lasted a good while untill two trips to the mx track and all the jumping took its toll.O well time to renew my licence so i'll get a new tag while i'm there.
2021 Africa twin.
2022 Kayo k6-EFI.
WELCOME TO THE DIRT SIDE.
2022 Kayo k6-EFI.
Re: Cracking tags
Practice safe tagging... use rubber...
Re: Cracking tags
I have done away with the tag bracket and drilled some new holes in the tag and bolted it directly to where the tag bracket was. We'll see how it does this weekend at the RORR ride.
Users browsing this forum: No registered users and 15 guests
