Running N->S might help w/ the weather. I suspect its sketchier / more variable the farther N you go. If you start there, you at least know you are heading in the 'warmer' direction. Whereas if you start at the southern end, you're depending on the weather forecast at the other end to be correct a week from now. Also fronts/rain typ seem to move N. So you'd be riding through it (N->S) vs stuck under it (S->N).
Could always load up a box truck w/ the bikes & two people plus also rent a car for the other riders.
Southern half - MABDR
Re: Southern half - MABDR
Same here. Work cut my first attempt short so I only did the northern half starting from Pen Mar. I'm hoping to get the southern part in next year with a U-haul down to the start... can't imagine 6 hrs of highway on the DR.
I'd definitely be interested in the NEBDR too as long unless the group size is getting out of control.
'06 DR 650
'81 GL500 (some assembly required)
That's a good plan. You can still rotate drivers between car and truck as well and do it all in one day. Once you get past Conn, it becomes a much friendlier drive for sure. Leave DC area around 4 am to get past NYC/Conn.
S->N would probably be more exciting knowing you’re always heading towards better terrain and then the ride back could also act as a sweeper if needed. Of course chasing a rain cloud north wouldn't be ideal.
'06 DR 650
its mentioned that the earliest someone should try to ride it in it's entirety is June 1st. Due to slippery and muddy conditions in Spring and early Summer. I don't know if they're saying that in general and accounting for the big bikes. Since we are all planning to be on DS bikes Is this something you guys are trying to do at June 1st? or earlier
I agree with everybody on everything else, planning is key. Also I remember the first time Ive heard of black fly season is when Angie and I went camping at the Adirondacks, we were out of there just in time according to the locals.
https://ridebdr.com/nebdr/
Users browsing this forum: No registered users and 61 guests
