Posted: Thu Aug 26, 2021 9:10 am
Just need an Alta to park beside them right?
Option C) Both! Even by noon the grass was still wet from dew. 100% humidity. I overheated and had a headache on the way home. Neither Dan or I expected it to be that hot.
I found a '21 Freeride E-XC w/ 6.6hrs & 104mi and a VA street title . I didn't get to test ride it much when I picked it up Mon night. He was in an RV park and I didn't want to go tearing around and make trouble. When I charged the batt and finally got to ride it around the house Tues evening I have to admit I was underwhelmed. I thought "its not nearly as fast as the SurRon" as it just doesn't try to wheelie/kill you constantly. They both make similar power (21kW = ~28hp peak.)
The '21+ got bigger Formula brakes compared to older Freerides. I don't know what was on the old ones but I parked the E-XC beside the 500EXC-F and they look near identical. Same basic rotor diam, thickness, and caliper & pad shape/size. One is marked Formula and one is marked Brembo is about the only difference I can tell. I might even bet the pads interchange (I need to actually look into that so I can have a spare set on hand if they are different.)
So we get to EB Wed morning and unload the bikes. We run a short loop (1.9mi) w/ Dan on his 450XCW and me on the E-XC and kiddo on his X160. After the warmup, I pull out the SurRon and Dan/I drag race the two. He's 30#+ lighter than me an on the E-XC. I'm on the SurRon. The SurRon will quickly pull about 1/2 a length at the start but then the KTM gets it back almost as fast and then slowly pulls away. We repeated several times and its the same each time. We swapped riders and same results. Dan also remarked the KTM feels much slower than the SR but when he looked down at the speedo was going 40+mph. It gains speed deceptively fast. Where the SR wants to wheelie and feel like its trying to kill you in mode 3, the E-XC just gets up and goes. The result surprised both of us. FWIW, the SR is setup: 60T sprocket, Nuc 24F (400A(?) phase, 300A batt), 72V/30Ah Litespeed, Fox 40/DHX2, 21/19" wheels. We parked the gas bike and Dan and I rode the electrics the rest of the laps.
So first ride review out on the trail:
The KTM brakes kick ass. Again, I don't know anything about the old ones but the Formulas are firmer than any Brembo I've used. They have absolutely beautiful feel. Dan remarked once he got into 'mountain bike mode' in his brain the LHRB was *SUPERIOR* to a foot brake. I rode it like a hooligan. You can effortlesly slide (or not!) the rear end into any turn. Even sandy right handers w/ you right foot stuck out. Swapping back and forth from the KTM to the SR highlights that the SR's brakes are complete shit in comparison (and they are 'decent' as MTB brakes go. The E-XCs are just on another level. Time to upgrade the SR brakes... ) Dan loved the lack of shifting. 'No thinking about need to be in this gear coming out of the next turn, or need to downshift twice before that obstacle, just twist and go and think more about riding.'
The throttle response in mode 3 is very 'gas like.' KTM did their homework. You don't have to remember you are on an electric when hopping something - it just responds like you think it should. Going back and forth between the SR & KTM, I think I should change the formers throttle curve to better match the latter. The KTM just felt that little bit 'better' off the bottom end. There is a little bit of free play in the KTM throttle I'll want to eliminate.
Suspension: The SR w/ the Fox setup is far more small bump compliant. But I definitely don't have the rear end of the SR dialed in as it still chatters under big power esp over roots. The E-XC is harsher but more dialed in out of the box. Eagle Bay is pretty torn up w/ LOTS of sand sections and ruts at the moment. W/ the KTMs extra mass, at 40mph its settled in and calm. I haven't touched anything like preload or checked the clickers yet. But so far so good. Doesn't ride like a wet noodle or anything (but EB is all TIGHT single track so things will change out in the open. I know the fork is damped SOFT.)
Size: The KTM is MUCH closer to a full sized bike than the SR. That said, the bars are still in the full rear stock position and it feels small. I need to set them forward and get risers like I have to w/ my other bikes. A stock 500 feels short to me w/ my orangutan arms & legs so I don't want to be harsh on the Freeride yet. What stands out on the KTM is its width. It is insanely narrow. Skinnier than my 150 by a good bit. Narrower than the play-bikes. Its just flat-out skinny. The jury is out whether the necessarily skinny seat will take its toll on my ass. I'm guessing it doesn't have enough range to be sitting on it long enough to ever find out.
Looking forward to taking it out to places that are more technical and see how it does. Will definitely take it (along w/ the 150XCW) to Kairos in Oct.
