Doohickey, valves, tires
I'm going to need to do the valves on the KLR soon, I did almost 900 miles today and it'll be another 550-600 miles till I get home tomorrow evening. It's due for it's 15k by then and I want to do the doo then too and I' m wondering if anyone has the doo tools I could borrow. Also, I seriously squared off the tires today with all that slab and I'll be lucky if I make it home without threads showing, going to ride home on the parkway so I can wear down the edges so I'm wondering if anyone has a balancer to true up a new set of tires once I get a set and spoon them on.
Mike B
08 HYM1100S
08 Raptor 250 SE
06 800SS
87 750 Paso
89 KLR650A
65 H-D M50
64 125 Bronco
08 HYM1100S
08 Raptor 250 SE
06 800SS
87 750 Paso
89 KLR650A
65 H-D M50
64 125 Bronco
Re: Doohickey, valves, tires
I have a Tachyon balancer you are welcome to use. I need to get some stick-on weights. I currently have a bunch of spoke weights. However, I've bought 3 sets of tires and have yet needed to balance the wheels. I did have to balance the KTM rims because the bead lock put the rims out of balance.21783mike wrote:I'm going to need to do the valves on the KLR soon, I did almost 900 miles today and it'll be another 550-600 miles till I get home tomorrow evening. It's due for it's 15k by then and I want to do the doo then too and I' m wondering if anyone has the doo tools I could borrow. Also, I seriously squared off the tires today with all that slab and I'll be lucky if I make it home without threads showing, going to ride home on the parkway so I can wear down the edges so I'm wondering if anyone has a balancer to true up a new set of tires once I get a set and spoon them on.
I've personally never done to doo. I had it done when I had the jug redone.
I'll PM you when it comes time to balance the tires. I've got a 25 hp kohler torn apart on the bench now which needs to go back together and back on the mower and a leaky head gasket on diesel Gravely that I needs to fix before I can do anything with the KLR. Mowing season is coming real soon, and I've got to get all the equipment PM'd , they were already mowing down in Ashville when I was there this weekend.
Mike B
08 HYM1100S
08 Raptor 250 SE
06 800SS
87 750 Paso
89 KLR650A
65 H-D M50
64 125 Bronco
08 HYM1100S
08 Raptor 250 SE
06 800SS
87 750 Paso
89 KLR650A
65 H-D M50
64 125 Bronco
25HP? Heck, put that baby in the KLR!21783mike wrote:I'll PM you when it comes time to balance the tires. I've got a 25 hp kohler torn apart on the bench now which needs to go back together and back on the mower and a leaky head gasket on diesel Gravely that I needs to fix before I can do anything with the KLR. Mowing season is coming real soon, and I've got to get all the equipment PM'd , they were already mowing down in Ashville when I was there this weekend.
Folks were mowing here in Middletown this weekend. Reminded me to ensure the neighbor kid was set to mow the yard this year again.
Unfortunately it's a vertical shaft so it'll only work on the mowers..... otherwise
Mike B
08 HYM1100S
08 Raptor 250 SE
06 800SS
87 750 Paso
89 KLR650A
65 H-D M50
64 125 Bronco
08 HYM1100S
08 Raptor 250 SE
06 800SS
87 750 Paso
89 KLR650A
65 H-D M50
64 125 Bronco
