I have a KLR that needs a GPS unit. Since you DAMN guys seem to use them a lot I thought this would be a good place to get some advice.
Brands, Do's -Don'ts, Any tid bit of info would be appreciated. I really don't want to spend the money on a high dollar waterproof one since in most instances I can put it into my tank bag if needed.
Input please>
GPS Thoughts
Re: GPS Thoughts
Weeeellllll.... I have a Garmin Zumo 550 but it qualifies as a high dollar waterproof one
Re: GPS Thoughts
I also have a Zumo550 I use on the Concours but I have a Garmin Quest II that I had used. I actually prefer the Quest for the way it navs and creates routes. It is compact and submersible but, if you do a lot of off road (rough) riding it can be a little tender, mine is on its way to Garmin to get the antenna put back on. I have ridden with a few guys that use the cheapo Wally world brands with success, they just put a zip lock baggy on them when it rains.
Re: GPS Thoughts
Wingfixer wrote:I also have a Zumo550 I use on the Concours but I have a Garmin Quest II that I had used. I actually prefer the Quest for the way it navs and creates routes. It is compact and submersible but, if you do a lot of off road (rough) riding it can be a little tender, mine is on its way to Garmin to get the antenna put back on. I have ridden with a few guys that use the cheapo Wally world brands with success, they just put a zip lock baggy on them when it rains.
You can usually pick up a quest or quest II for less than a 100 buck on advrider or ebay... The antenna is the only weak spot - but you can buy an extension for like $20 bucks so you don't have to open it up.. It's very durable overall...
The main issue you are going to have with older waterproof models (remember the most of the current models in cars are not outdoors friendly) so the older/cheaper models will NOT be touch screen and they won't be quite as friendly when mounted on the bike...
Re: GPS Thoughts
If you are going to be a GPS dork, might as plan of signing up for events like the Pine Barrens 300/500.
It will still probably be awhile before I ever get one, but that event really made me think about it.
Re: GPS Thoughts
After reading some posts and not being real sure how often I will use a GPS on the bike I bought a Garmin 200 Refurb off of Newegg.com for 89.99 with shipping. If I end up using it a lot[ie being a GPS dork] I will put down the money for a waterproof unit. However if I don't use it that much and this one gets destroyed I am out $90, no big loss. Now maybe I can make some entries on dinners since GPS coordinates are required.Thanks.
