Brake pistons
Re: Brake pistons
Post by Wingfixer » Tue Mar 20, 2018 10:56 am
Fuckin KTM...
Re: Brake pistons
Post by Laoch » Tue Mar 20, 2018 11:14 am
Fuckin KTM...
:lol2:
2016 Freeride/'03 KLX 400/'13 CB500X
Re: Brake pistons
Post by Laoch » Tue Mar 20, 2018 11:17 am
gots_a_sol wrote:
Tue Mar 20, 2018 10:11 am
Clearly you need to use fire to remove them. Can't be stuck if they are liquid :lol2:
Good idea.
Re: Brake pistons
Post by Laoch » Tue Mar 20, 2018 11:18 am
Nobody wrote:
Tue Mar 20, 2018 9:44 am
Laoch wrote:
Tue Mar 20, 2018 8:29 am
Fuckin shit. Plastic pistons. Two popped out. Two are stuck. Probably why i can't stop. Now what...ideas? Ordered ss replacement pistons.
Interesting, how many use plastic pistons nowadays? Seems to be not too good in a place which theoretically can become quite hot..
yeah.
http://www.rideformula.com/
Re: Brake pistons
Post by Laoch » Sat Mar 24, 2018 12:23 pm
New ss boron coated something or other. It was harder getting the new ones pressed in. All bled. Now to test, bleed and repeat. Hopefully I will have front brakes.Image
Nobody
Re: Brake pistons
Post by Nobody » Sat Mar 24, 2018 12:35 pm
note to myself: "If you want a KTM, don't buy a Freeride" :lol2:
Re: Brake pistons
Post by juddspaintballs » Sat Mar 24, 2018 1:05 pm
Bruce, snag a 60cc syringe with a blunt tip, 1/4" aquarium tubing, and brake fluid. Put the tubing on the syringe and attach it to the bleeder. Open bleeder and push fluid up into the master cylinder until no more bubbles. Air bubbles like to rise and this method works great on bikes.
KTM 450 EXC
Re: Brake pistons
Post by Laoch » Sat Mar 24, 2018 1:26 pm
Jed- :thumbup: I think I did my clutch that wayu. So fsr so good.
Janis- :duel:
Re: Brake pistons
Post by J&J » Sat Mar 24, 2018 3:11 pm
“Phenolic pistons reduce heat transfer into the brake fluid, resist corrosion that could cause caliper binding and are lightweight.”
That’s what the “smart guys” say. Most vehicles have them now.
I’m not a sart guy though, just sayin....
And I’ve seen them break if not pushed back evenly. :shrug:
Users browsing this forum: Bing [Bot] and 0 guests
