Page 1 of 3
Handlebars
Posted: Mon Mar 05, 2018 4:46 pm
by BamBam
What do you guys think about handlebars and this whole vibration/fatigue thing? (especially given my old KDX bike)
Would it make a difference going to something like a Mika pro 7/8" bar that claims to allow more flex and reduce fatigue? Would it be bigger benefit and worth the hassle going up to a 1-1/8" fat bar and changing the bar-clamps and having to screw around with the acerbis handguard brackets?
Is anyone filling the inside of the bars with weight to dampen vibration?
Re: Handlebars
Posted: Mon Mar 05, 2018 5:25 pm
by Rut Row
I guess I don't ride enough. Vibration has never been a problem for me.
Re: Handlebars
Posted: Mon Mar 05, 2018 7:46 pm
by Wingfixer
I guess I ride new bikes enough. Vibration has never been a problem for me.
Small fix.
To answer the question with tongue in cheek, I did find that installing the BRP mount on the Beta smoothed some of the high frequency vibrations.
Re: Handlebars
Posted: Mon Mar 05, 2018 8:02 pm
I think any "good" aluminum bar will reduce vibration. That and good grips.
Only bike I ever had with vibration issues was the mighty KLR. :roost:
Push-ups help :lol2:
Re: Handlebars
Posted: Mon Mar 05, 2018 9:43 pm
by BamBam
"Good" aluminum bars to reduce vibration come in both 7/8" and 1-1/8". Or should I only be looking at 1-1/8" bars without crossbrace?
Is there something special in the design of BRP clamps to inhibit vibrations, or does that just come from quality manufacturing and beefy mass?
Re: Handlebars
Posted: Mon Mar 05, 2018 9:55 pm
by Wingfixer
It's an isolation mount. If you zoom in you can see the polyurethane isolators, the red parts. The mount came with the red and a blue (softer) set. I couldn't tell any difference so went with the red set 'cause they match the bike. :lol2:
Re: Handlebars
Posted: Tue Mar 06, 2018 7:15 am
IMHO fat bars are for "hard riding". IE jumps, mx, etc. Either or will work. If your running stock bars right now, you should see a difference with any kind of upgrade. Or go the WF route, cuz you know those Betas shake a lot.
Re: Handlebars
Posted: Tue Mar 06, 2018 7:52 am
by Wingfixer
:dirtdog:
Re: Handlebars
Posted: Tue Mar 06, 2018 8:46 am
by Marylander
If you go with some AL bars and find they don't do the trick I've got some internal weights you could try out (these: https://www.fasstco.com/collections/mot ... on-inserts). They came with my flexx bars but I never used them. You could probably use some kind of rubber plugs to make them fit into steel bars...
Re: Handlebars
Posted: Tue Mar 06, 2018 1:58 pm
by BamBam
Last year I replaced stock steel bars with aluminum 7/8" Tag X5 bars (they were $25 on sale). Was a hassle getting the acerbis hand guards moved over, but I eventually managed.
Seems to me from an engineering standpoint that these fat-style handlebars without crossbars would have even less vibration all things being equal. Do you think its enough of a difference for a noob rider (who gets tired arms) to notice?
It's an expensive swap ($200 for the BRP fat bar mounts and then pro taper Evo bars). But if you think it would make a real difference I would give it a try. And then fight the acerbis battle again. Ooofa.
If the style bars don't make that much of a difference for vibration, I could experiment with filling my bars with weight. Someone mentioned liquid rubber, which makes sense from a weight and vibration damping standpoint.
Marylander - its very nice of you to offer those Flex inserts. Once I get the bars sorted out (height, design, etc.) if I still have problems I will take you up on that!
