Yup - ended up buying new bolts and lock nuts (much needed) and also had new spacers made so I could ditch the plethora of washers used.davej wrote:ken, did you get the motor re-fastened to the frame? i felt bad bringing it back in like that. i think the monkey was a bit nervous but i had fun scooting around. dave
Currently all the shocks are being rehab'd and the new crack in the frame is being welded. Also, the vibration from the loose mounts cracked the expansion chamber . But... the bike is 24 years old! It deserves a little more attention before we abuse it again!
