Shop in frederick??
- DAMN n00b
Shop in frederick??
Wheres the best place in or nearish frederick to take my cfr 450x with seized motor?
Re: Shop in frederick??
I can't really recommend a Honda shop, but I'm guessing unless it's a relatively new bike, by the time you pay shop rates, it would probably be cheaper to replace the whole bike, or at least the engine/trans with a good condition used one.
You could Tri State Cycles in Funkstown, Md. Not too far from Frederick. Straight shot up 40A.
301-797-8130
301-797-8130
Retired and loving it!
- DAMN n00b
05 crf 450X
I want to take it in, it had been running great with a little trouble starting and I did the gentlest washout on the right side and it was seized up, I suspect maybe a problem with the starter clutch???? I know it had been going, I've heard honda used little plastic rollers that are know to wear(though I've never had it apart myself) Kickeded it with a little force and it freed up but wasn't able to start the bike, at that point the starter would just whizz wouldn't crank the bike. after a few attempts to push start the bike it seized up again and I don't want to force it for fear of damaging something. Is it possible the stater clutch broke and is half stuck engaged to the crank? I have only a vague understanding of how it works since I haven't had it apart that far before.
- stretchride
Dutrow Honda is in Frederick, north on the golden mile just outside the built up area. I stopped by and discussed a problem with a mechanic there once and he was helpful but I havent had work done there, maybe someone else has and will speak up...
Did you happen to remove the plug? Just curious if it could be hydrolocked?
_________________________
StretchRide
04 KTM 450 EXC-G Racing
06 Honda XR650L
StretchRide
06 Honda XR650L
Dutrows would be a good choice. I always received great service when I had a Honda.
Member R&T Club, and GMER
- DAMN n00b
hydolocked?
I haven't spent any time messing with it, I was so upset that I couldn't ride the rest of the day tuesday, I just threw it on the truck and stuck it in the garage.
I did notice once the bike got warm it was oozing air cleaner oil. I had just cleaned it and apparently I over did it with the oil. Think maybe I sucked that crap into the carb?? Would that cause it to seize up like that?
Just take the plug out and try to push it in a high gear to see if the engine spins and that there's nothing in the cylinder.
We have crf 250r's & if they get upside down (it happens) oil will drain from the valve cover to the aircleaner.... enough oil could get into the cylinder to hydrolock it (oil will not compress) Take out the plug & try to kick it first, then if it kicks you can try the starter. If it won't turn over with kicker put it in 4th or 5th & try to roll bike with plug still out, that will tell you if you have a problem with the starter. If it's hydrolocked it should clear out with a few cranks. If it's oil then you might need a new plug.DirtyRooster wrote:hydolocked?
- DAMN n00b
Ill try those suggestions this weekend but as of right now I can't kick it at all the kick starter is frozen solid.
