Front wheel rim lock; what is the point?
Should I do away with the front wheel rim lock on my 520 EXC? Why, or why not?
TIA
TIA
Re: Front wheel rim lock; what is the point?
I've seen you ride - - leave it on, and some self tappers through the rim into the tyre bead!
Honestly don't know - - probably something to do with low tyre pressures holding the bead to the rim, and the sudden acceleration / deceleration on rough terrain. They are a PIA when changing tyres 'though, aren't they?
All the best
Ray
All the best
Ray
2012 Triumph Tiger 800
Actually, they're not so bad when changing the tire -- you have to make sure the lock is good and loose, then put the tire irons opposite the lock. To install a tire, arrange the bead under the lock before you put the tire irons under the bead. Again, put the tire irons opposite the lock.
Bead locks allow the use of very low pressures which can benefit traction.
I always install the bead over the valve stem, which is all but impossible to install once you have the first bead on the rim. I didn't have any trouble with the rim locks. They are a bit fiddly, but with patience (what is that? ), they are easy enough to deal with. I am still not sure why the front needs a rim lock, although it might keep the tire beaded if you get a flat, allowing you to limp on.
The new tires have been mounted for most of a week. I am dying to give them a try.
the front rim lock is to keep the tire from moving on the rim. It will bend the valve stem til it rips the tube, i have spun them even with a rim lock install. braking is what gets the front wheel, throttle gets the rear with same effect.
There you go Mike! You can eliminate the front rim lock - we all know you don't use brakes - just throttle!Hare wrote:the front rim lock is to keep the tire from moving on the rim. It will bend the valve stem til it rips the tube, i have spun them even with a rim lock install. braking is what gets the front wheel, throttle gets the rear with same effect.
My brakes don't work, even if I wanted to use them.Kyler wrote:There you go Mike! You can eliminate the front rim lock - we all know you don't use brakes - just throttle!Hare wrote:the front rim lock is to keep the tire from moving on the rim. It will bend the valve stem til it rips the tube, i have spun them even with a rim lock install. braking is what gets the front wheel, throttle gets the rear with same effect.
OK, now your riding makes sense.....
:lol8:
:lol8:
Look Ma, no brakes!!!Roadracer_Al wrote:OK, now your riding makes sense.....
:lol8:
They also let you ride on a flat.
Users browsing this forum: No registered users and 0 guests
