DAMN Ebay
DAMN Ebay
I bought Motion Pro throttle cables, to fit my DRZ 400. They only fit backward (roll throttle forward to accelerate). WTF Just a little warning for other DRZ guys.
Sorry, looks like I goofed. The listing could have been better. It's an E model cable set, and it's for sale $20 local pick up.
Re: DAMN Ebay
Check the part numbers?
Btw, I think I can take you at Greenridge, finally, If you're stuck in reverse.
Re: DAMN Ebay
restukey wrote:Btw, I think I can take you at Greenridge, finally, If you're stuck in reverse.
Re: DAMN Ebay
The Ebay ad said drz 400 s 2000 to 2010. I can still use it, just have to roll the throttle tube forward instead of back.restukey wrote:Check the part numbers?
Might be a close one at Greenridge
Re: DAMN Ebay
you're pullin' our leg, right?frogman1981 wrote:The Ebay ad said drz 400 s 2000 to 2010. I can still use it, just have to roll the throttle tube forward instead of back.restukey wrote:Check the part numbers?
dual-cable control, right?
switch cables around?
Re: DAMN Ebay
Crap, I just realized your going to be stuck in fast forward. Return that cable!
All kidding aside, I think you might be able to rotate the throttle housing a little and change the slack? I remember the same issue on my Husky. If it were an FCR, I'd say to forgetabout the return cable. I cut mine when it frayed, no issues. Not sure how that would workout on your carb?
Re: DAMN Ebay
I wish I could but it wouldn't fit, not long enough.Kyler wrote:you're pullin' our leg, right? Not at all.frogman1981 wrote:The Ebay ad said drz 400 s 2000 to 2010. I can still use it, just have to roll the throttle tube forward instead of back.restukey wrote:Check the part numbers?
dual-cable control, right? Right.
Re: DAMN Ebay
call motion pro direct, they are very nice easy people to talk to and will straighten out whatever is wrong, they are total pros
motion pro
650.594.9600
motion pro
650.594.9600
Re: DAMN Ebay
Thanx for the info, I figured out the problem though. Looks like I ordered a cable set for a E (off road) model DRZ. Oops.Hare wrote:call motion pro direct, they are very nice easy people to talk to and will straighten out whatever is wrong, they are total pros
motion pro
650.594.9600
I still haven't heard from the seller.
Anybody with an FCR carb need a cable set?
