KTM620Adv Exhaust relocation for Hard Bags
hondahawkrider
Re: KTM620Adv Exhaust relocation for Hard Bags
Post by hondahawkrider » Thu Apr 22, 2010 3:28 pm
Kyler wrote:I've been thinking about this. I think he should run the exhaust straight back, then up at a 90 deg angle behind the cases - sorta like diesel stacks. :poser:
You laugh....
However I have been lurking on allot of KTM sites looking for someone to part with a set of KTM 690 SM OEM pipes.. Cheap, like I see with the 950/990 ones (you can get a set for $50 on Adv rider)
It's not going to be a passenger bike - so I could move the bags forward a bit and pop these up behind the bags..
hondahawkrider
Post by hondahawkrider » Thu Apr 22, 2010 3:33 pm
mdubya wrote:Would it be possible to do a single exhaust routed back through the subframe ala 625?
Not without getting a different subframe ... See the 2nd pic... The rear is reenforced to hold extra weight on the tail... It was KTM's Rally bike model of the day, they didn't have a seperate rally bike like they do today...Supposedly it was done to be able the weight of aftermarket rear tanks...
Roadracer_Al
Post by Roadracer_Al » Sat Apr 24, 2010 12:25 pm
IMHO, the water in the pipes thing is a non-issue.
I've had to build racks to keep from melting soft bags and side plates on both our bikes, and that's a big PITA. IMHO, the low pipe solution is good. It's even better if you can easily swap back and forth between the high & low pipes.
If you don't mind the looks, you could try to find a thin/flat automotive muffler to position it behind the bags. I'm thinking something like a Bassani universal muffler. The downside is that they're probably heavy, not to mention somewhat too-large inlet/outlet diameters. I'm sure with more research, you could find smaller diameter, flat, offset inlet/outlet universal mufflers.
http://www.autoanything.com/exhausts-mu ... =ffproduct
Also, you could modify your bag mounts to allow more space for the mufflers, and possibly add heat shields.
Users browsing this forum: No registered users and 15 guests
