Cracking tags
Cracking tags
As I sit here in the MVA again, I was wondering if anybody else has a problem with losing their licence plate due to it cracking. I'm on my third tag in two years. Each one has cracked across the bolt holes and falls off. The last one I used extra large washers and rubber washers between the plate and steel washers. Is this normal to go through this many plates? I know its the vibration causing this, but I can't figure out a way to stop it. I'm thinking I'll try mounting this new one to an aluminum backer plate. Any other suggestions?
Re: Cracking tags
This was an issue on my KTM Duke. The tag bracket vibrated so bad, a plate would not last more than a few rides. Then the bracket itself did me a favor and cracked and broke off too. Next plate got screwed to the airbox inside the rear fender. It was clearly visable from the rear, but not legal. But it was better than no tag at all. I had plenty of complaints and grumbles from the po. I simply said that was where the tag was mounted when I bought the bike (not true, but I had seen many set up that way before as it was a common LC4 problem).
If you aren't willing to go that route, try mounting it with a bunch of zip ties. This keeps the metal from getting overly stressed and good zip ties are strong.
DRZ S and SM
Vertemati SM
KTM 520 EXC
Vertemati SM
KTM 520 EXC
Re: Cracking tags
I'm on my third tag also. I drilled holes in the middle of the tag (i was in a hurry). The tags are really thin.
Re: Cracking tags
Maybe try adding a few more holes. I normally try to mount with 4 holes...
Another option might be to mount it using zip ties. That way it would have some flex in the mounting and maybe not vibrate quiet as bad.
- DAMN Poohba
Re: Cracking tags
+1.. For single cyclinders - I usually will drill two extra holes and run zip ties thru em (usually at the bottom of the tag) for the older bigger MD tags. If you are running two bolts at the top it's way easier for it to vibrate and crack along the top.. I originally put the zip ties on the bottom to secure the tag better so when (not if) it cracked the zip ties would at least save me from losing the tag.. Since I have done that - no loss of tagcrofrog wrote:Maybe try adding a few more holes. I normally try to mount with 4 holes...
2013 Honda CB1100
1999 Suzuki DR350Se
2013 Honda CB1100
1999 Suzuki DR350Se
Re: Cracking tags
hondahawkrider wrote:+1.. For single cyclinders - I usually will drill two extra holes and run zip ties thru em (usually at the bottom of the tag) for the older bigger MD tags. If you are running two bolts at the top it's way easier for it to vibrate and crack along the top.. I originally put the zip ties on the bottom to secure the tag better so when (not if) it cracked the zip ties would at least save me from losing the tag.. Since I have done that - no loss of tagcrofrog wrote:Maybe try adding a few more holes. I normally try to mount with 4 holes...
It sounds like we do it exactly alike...
I also use those rubber washers that ace hardware sells. For the bolts.
Re: Cracking tags
My tag bracket only mounts to the top two holes of the tag. I think I'll try the wiretie idea this time though. I dont know why I never thought of useing them on the bike. I have used them for years on my universal trailer tag. Makes for quick and easy transfer.
Re: Cracking tags
i have some stainless steel lashing wire. Thats what i used on my trailor tag u can use this stuff for anything, its strong and doesnt corrode
Re: Cracking tags
Last time I was up at Granvilles, I lost my plate and holder somewhere in the woods (about a month ago). If anyone gets back up there before I do and comes across it, let me know. Not happy about giving MD another $100 for a plate.
Users browsing this forum: No registered users and 16 guests
