Test Site - need help please
Re: Test Site - need help please
The "Outbox" is messages that have not been read, while the "Sent" is ones that have been read.
Gotcha. Thanks for the clarification.
The naming convention for those folders seems a bit odd then. I wouldn't be opposed to reducing it to just an inbox and outbox. Just a suggestion, knowing its functionality now makes it less annoying.
'06 DR 650
'81 GL500 (some assembly required)
that's been proposed before and the response was
https://www.phpbb.com/community/viewtopic.php?t=2458131This is the best implementation. In a traditional e-mail system, the message leaves the server and then leaves the outbox, it's different here. Much better. Without additional things, the sender knows that the recipient has read the message. As long as the message is in the outbox, the sender knows that the recipient has not read it, so he can change it or cancel it as KevC wrote. Such a good solution is possible because PM does not leave the server.
Looks like the secure https site is down? I'm not getting an expired certificate warning or anthing, just says the https site doesn't exist. It used to not do that.
Interesting. I didn't know I had HTTPS service. Will check into that.
Users browsing this forum: No registered users and 8 guests
