6x12 cargo to toy hauler conversion.
Re: 6x12 cargo to toy hauler conversion.
smdub wrote: Tue Nov 17, 2020 10:36 am
juddspaintballs wrote: Tue Nov 17, 2020 8:51 am The Mr. Buddy danger is oxygen consumption, not CO emissions. It has an auto shutoff for low oxygen, but keeping a window cracked is still a good idea.
If all goes well...
C3H8 (propane) + 5 O2 (oxygen) = 3 CO2 (carbon dioxide) + 4 H2O (water)
when you start to run short on O2...
C3H8 (propane) + 4 O2 (oxygen) = 1 CO2 (carbon dioxide) + 2 CO (carbon monoxide) + 4 H2O (water)
thus: oxygen consumption = CO emission
Relying on its low O2 sensor to prevent carbon monoxide poisoning is putting all your eggs in one basket.
This brings up another interesting science fact. For every # of propane burned, you release ~1.6# of water into the air. The Mr Buddy uses those 1# bottles. I've seen them go through one a night if not insulated well. Thats 3/4L of water in the air (excuse me for going over into metric to make calculations easier.) IIRC, a human sleeping exhales about 1/4L/night. So that like having 3 more people in the trailer w/ you. FWIW, my family of 3 sleeping in the van generates noticeable condensation inside overnight. Not dripping, but a noticeable 'film' on everything.
The heater consumes enough oxygen to trigger low oxygen long before it produces enough carbon monoxide to be unsafe. Even if the oxygen sensor didn't work and the heater kept running, the environment would have low enough oxygen to not only kill you but also stop combustion. Due to how efficient the catalytic heater is, the carbon monoxide emission is still so low it isn't a concern. A low oxygen environment is immediately deadly.
Like I said, it's a good idea to keep a window cracked. It's not because of CO emissions, it's because of oxygen consumption. When I run mine, I keep the roof vent open and a window cracked.
The real solution is a furnace that does all of the combustion outside of the living space or an electric heater. Both of those options are safer and don't put moisture in the sleeping quarters.
Brent, I installed strips of L-Track on the bed rails of my truck. It's as versatile as E-track, but much smaller. I forget what each connection point is rated for, but it well exceeds the load a dirt bike would put on it.
smdub wrote: Tue Nov 17, 2020 10:36 am Thats 3/4L of water in the air (excuse me for going over into metric to make calculations easier.)
NEVER apologize for using the metric system.
juddspaintballs wrote: Tue Nov 17, 2020 7:53 pm The real solution is a furnace that does all of the combustion outside of the living space
Thats why I suggested one. They are down to the same cost as a Mr buddy heater. Uses much cheaper fuel to boot.
I had never heard of diesel heaters but from a few videos on YouTube I think the noise would make them a no go for me. Most of the campgrounds I camp at with the family have generator limited times. They are pretty cool devices though.
2012 Ktm 500xcw
Dan doesn't have a muffler on his and its still pretty quiet. *NOTHING* like a generator (even a Honda 2200i at idle). Sorta sounds like a big propane torch. Maybe closest to one of those propane torpedo heaters? It was not completely silent but it quickly became background noise. The campfire was louder.
We have a SPL meter at work. I didn't order the optional exhaust muffler but mine is coming w/ an intake silencer. Will measure SPL once I install.
smdub wrote:Dan doesn't have a muffler on his and its still pretty quiet. *NOTHING* like a generator (even a Honda 2200i at idle). Sorta sounds like a big propane torch. Maybe closest to one of those propane torpedo heaters? It was not completely silent but it quickly became background noise. The campfire was louder.
Can you send a link for the one you got?
2012 Ktm 500xcw
Webasto Air Top 2000 STC (STC is the newest version. ST is older)
Can order from Russia for about 1/2 what you can find them for here. $600.01 shipped and it went out the next day. (I was leary but the "heaters4you" guy gets a lot of excellent feedback on the forums.) No warranty if you don't order from an authorized US dealer though. I figured for the price difference I can fix it myself if I have a problem. There is a $50 USB diagnostic cable and DVD on ebay that can do OBD2-like stuff if its ever needed to help repair.
https://heaters4you.com/for-areas-less- ... 00-st.html
Webasto and Espar/Eberspacher both make fairly identical diesel ones (similar $1200 list price). Those are what the chinese companies copied for $100. Unfortunately Webasto is the only company making gasoline ones so I had to pony up 6x as much to not have to hassle w/ a 2nd tank. If the van was diesel or if I was installing in a trailer I'd definitely get the diesel version. FWIW, Propex makes a propane powered one but you can't find it anywhere for cheap.
Since there was a diesel version of the ProMaster, there is a blank spot behind the gas door that was used for DEF. Some folks have figured out what the DEF cap and filler neck part numbers are. They used those plumbed into their own small diesel tank for the heater. I thought that was pretty clever. Its documented on the forums what the part #s are but I didn't want to mess w/ fabing a custom tank right now just to use diesel when a huge supply of gas is already RIGHT THERE.
If you want info on the chinese diesel copy, Dan is ClutchDumpinDan on ADVRider. He doesn't have a link to the exact heater he got. Just said he bought one off ebay. All the copies are likely made in the same place so seller probably doesn't matter. Here is his van build thread:
https://advrider.com/f/threads/adventur ... e.1273710/
FYI- the military has been using different versions of fuel heaters for many years. Very efficient and safe, but we always vented. Or lacked any sort of actual enclosed space :lol2:
KRKid
Post by KRKid »
Nice. How you liking it? Got to use it much?
I’m a few months late to the thread. I’ve been doing the same with a 7x14. I did install one of the diesel heaters in my trailer and it works pretty good, pumps out some serious heat. Bought one of the all in one versions on Amazon just to make it little easier install. Did some 12v power, lights, usb outlets, etc and got a couple cots to sleep on if I need it.
Hope to try to meet some more of you guys and ride at some point. Only met a few of you through Phil being a great host in emmitsburg once. Bought a pass to FRO in little while back, anyone ride up there?
KRKid wrote: Thu Feb 04, 2021 8:46 pm Nice. How you liking it? Got to use it much?
Re FRO: I did get a FRO pass this year. I didn’t get one the last 2 or 3 years. I’m not into the gnarly single track anymore. Nice two track atv stuff and dual sport’ish Jeep trails.
They will be snowed in for a while up there. It is a great place to ride. Might still be a few guys here who ride there. Best bet is northeast forum on TT. They have a FRO meet up thread.
