better fuel filter
better fuel filter
Found these today while surfing around for all of you with fuel injected bikes with those weak ass Mahle plastic stock filters.
https://www.speedwaymotors.com/Earls-73 ... 93630.html
Rated for FI and 30 micron. Aluminum body so should work great I would think. Good price. ~14 bucks.
Re: better fuel filter
I use a tank sock deal filter thing. And the tiny little one at the connector. Where does this one go?
Its the one in the tank inline w/ the pump.
Ah. Lots of filters on these bikes.
The stock Mahle 97 plastic filters are prone to splitting and causing a loss of fuel pressure. Some guys run the metal ones you can get from Auto parts stores but they are not really made for fuel injection and the ~50psi pressures, but these are. Something as simple as a shitty filter can ruin your day on a long ride.
