Post by gots_a_sol » Sun Mar 01, 2020 8:47 am
Noice, definitely jealous of that!
Post by Laoch » Mon Mar 02, 2020 4:39 pm
Trying to sort out the carb on my garage queen Beta. She was pissing gas for a minute.
Post by Bucho » Mon Mar 02, 2020 9:30 pm
Sweet Beta!
Post by Rut Row » Tue Mar 03, 2020 7:14 am
The alternator seized on my Kubota L2250 tractor. I've been expecting that since the charging system is kaput. No big deal since it is a diesel; just charge the battery frequently. I had a regulator waiting and a chinese alternator was only $70. Got a new belt from NAPA for $10 or so.
The alternator is easy to get to. Had it off in 15 minutes. There is a fan shaft that runs from the water pump forward to the fan. It is supposed to collapse like a PTO shaft. Two hours later, and two cans of PB Blaster, the rain started. &^%$# shaft is rusted tight and it isn't obvious how to get it off without disassembling the front of the tractor. ARGHHHH!
Nobody
Post by Nobody » Tue Mar 03, 2020 7:17 am
post a pic so that we all can laugh :lol2:
Post by Laoch » Tue Mar 03, 2020 8:35 am
You should have left room in your garage to do actual garage work :lol2:
Try heat to loosen it up.
Post by Rut Row » Tue Mar 03, 2020 2:18 pm
I hope someday to have space in the shop for this kind of work :pray:
It's the shaft that sticks out of the pump pulley. I think I can get the spacer (those nuts in the middle are where the spacer should be) out and slide the belt through there. If not, will be getting out the torch!
Post by Boom Boom » Tue Mar 03, 2020 2:26 pm
It is ORANGE, what do you expect?
Post by Marylander » Tue Mar 03, 2020 3:17 pm
I didn't actually do any real work yet but I found the source of the coolant that's been dripping from my versys. A rock or something punctured the radiator. I managed to find an oem one on ebay that looks good. It was a little more than a new one from China but I decided to go the safer route.
Post by Wingfixer » Tue Mar 03, 2020 4:16 pm
Myler's Radiator does awesome work!
https://www.motorcycleradiators.com/pro ... tor-repair
Users browsing this forum: No registered users and 3 guests
