Saturday 4/13
Re: Saturday 4/13
Nobody wrote:
beejaytee wrote: Wed Apr 10, 2019 9:03 am I still have that. It’s yours if you want it.
I also have a JD fuel tuner I’m gonna sell.
I've never used those things. Would that help with starting? I often have trouble starting it if I stall it. At least until I put it in Neutral.
I've tuned up a TPS idle voltage a little bit. To 0.63. It helped a little bit but it's not perfect still.
The JD tuner will help with that a bit. These bikes are lean from the factory for emissions reasons. Lean makes heat and hot bikes don’t like to start. This allows you to adjust your FI bike in 6 different areas of fueling. This is fueling only not timing like a vortex ignition or different ignition map. It’s a pretty sweet item for bikes with a locked ECU. If you have anymore questions PM me Yanis.
2012 Ktm 500xcw
Re: Saturday 4/13
Post by J&J »
:thumbup: Thanks, I'll give you a call when I can get down your way.
Re: Saturday 4/13
I'm probably going to buzz around Michaux on Saturday. Weather looks good.
Re: Saturday 4/13
Re: Saturday 4/13
Laoch wrote:I'm probably going to buzz around Michaux on Saturday. Weather looks good.
I’m in if that’s the case.
2012 Ktm 500xcw
Re: Saturday 4/13
beejaytee wrote: Thu Apr 11, 2019 10:29 am
:thumbup:
You riding or hauling?
Meet up at my place in the woods or somewhere else?
Time?
Re: Saturday 4/13
[/quote]
:thumbup:
Time?[/quote]
You tell me trail master.
I’ll be hauling up cause I can drive faster than I ride. I’m getting off shift that morning so best case scenario I’ll be loaded and leaving around 7 at the earliest. Not time restrictions for me that day.
2012 Ktm 500xcw
Re: Saturday 4/13
I'll be at my place around 0900. You still know where it is?
Re: Saturday 4/13
Yeah. I’ll see you there.
2012 Ktm 500xcw
Re: Saturday 4/13
Should be no dust tomorrow!
