Post by Wingfixer » Wed Apr 03, 2019 5:07 pm
Nice! I'm calling dibs on the northeast corner!
Post by Laoch » Mon Apr 08, 2019 6:54 am
Got some walls built. Got 4/6 built. Ran short of 2x4's. Heading to Lowe's this morning for more.
I'm going to build the longer walls, 16 feet, in two sections to make it easier to stand up by my self.
'19 FE250/some trials bikes
Post by Laoch » Sat Apr 27, 2019 4:51 pm
Skipped out on riding to get some work done.
Question- 2x6 rafters 18 OC, 18 ft span and 12 ft wide. 8/12 pitch. 7/16 osb on roof is good?Image
Taylor
Post by Taylor » Sun Apr 28, 2019 9:23 am
I wouldn’t, go 16” OC with 7/16 osb/plywood. If you jump up 5/8” you could go 24”OC either way will probably cost the same.
2012 Husky WR 125
2009 Husky TE 310
2001 Harley FLHR
Taylor
Post by Taylor » Sun Apr 28, 2019 9:31 am
One other suggestion, to get it dried in fast use ice and weather shield instead of roofing paper. It won’t blow off if you can’t get the shingles on in a day and will protect the sheathing from swelling.
2012 Husky WR 125
2009 Husky TE 310
2001 Harley FLHR
Post by Laoch » Tue Apr 30, 2019 6:05 am
:thumbup: 5/8 it is. Still going to do like 20" OC just because the math works out better.
Also I really like the ice and weather shield idea, that is a winner.
Post by Laoch » Fri Jul 05, 2019 5:37 am
Windows going in this weekend. Door next. Then a little solod stain on the exterior
Post by Wingfixer » Fri Jul 05, 2019 11:16 am
I didn't realize you drove for nascar! How much sponsorship did you get? :jack:
Post by Laoch » Mon Jul 22, 2019 5:38 pm
About done till winter. I under estimated the time commitment. Image
Post by Laoch » Mon Jul 29, 2019 5:59 am
Getting thereImage
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
