It was fine during the day. Now it is slower again. It's nowhere near as bad as it was, but still..
Usually it loaded page/reloaded almost instantly. Now it is like 3-10 sec waiting time.
Edit: Posting this took around 50sec..
Website slow?
Re: Website slow?
Re: Website slow?
thanks. any others?
Phoo - what does the log say?
Re: Website slow?
Took me over 30 seconds to load the main page tonight
Re: Website slow?
I found a few times of slowness, no pattern I could see. Some really long times but mostly normal. That sql error is a good indicator, but I didn't add anything to look for that in my script.Rut Row wrote:thanks. any others?
If you want, I can email the full log to you. I km polling the site every fifteen minutes.
Re: Website slow?
no, with no pattern there's nothing to troubleshoot. thanks for doing itphoo wrote: ↑Sat Sep 15, 2018 11:15 amI found a few times of slowness, no pattern I could see. Some really long times but mostly normal. That sql error is a good indicator, but I didn't add anything to look for that in my script.Rut Row wrote:thanks. any others?
Re: Website slow?
So, there were serious delays when I started taking stats on Sept 5th. There were serious delays on the 6th, 7th, and 8th, too. But the delays of significance have gotten much better, and the duration of the longest delay is much shorter now. Whereas on the 6th I had a load time that was over two minutes (!!), the longest in the past three days was once it took 6 seconds but usually a load > 1s was less than 3. Yesterday (the 17th) only four loads took longer than a second and today there was only one so far. So hopefully whatever was going on is settling down.
Re: Website slow?
phoo wrote: ↑Tue Sep 18, 2018 2:54 pm So, there were serious delays when I started taking stats on Sept 5th. There were serious delays on the 6th, 7th, and 8th, too. But the delays of significance have gotten much better, and the duration of the longest delay is much shorter now. Whereas on the 6th I had a load time that was over two minutes (!!), the longest in the past three days was once it took 6 seconds but usually a load > 1s was less than 3. Yesterday (the 17th) only four loads took longer than a second and today there was only one so far. So hopefully whatever was going on is settling down.
