DAMN maintenance and repair thread; including Farkle Fests!
- aka FlatFixer
Post
by Wingfixer » Tue Mar 20, 2018 11:56 am
Fuckin KTM...
Post
by Laoch » Tue Mar 20, 2018 12:14 pm
Wingfixer wrote: ↑Tue Mar 20, 2018 11:56 am
Fuckin KTM...
Post
by Laoch » Tue Mar 20, 2018 12:17 pm
gots_a_sol wrote: ↑Tue Mar 20, 2018 11:11 am
Clearly you need to use fire to remove them. Can't be stuck if they are liquid
Good idea.
Post
by Laoch » Tue Mar 20, 2018 12:18 pm
Nobody wrote: ↑Tue Mar 20, 2018 10:44 am
Laoch wrote: ↑Tue Mar 20, 2018 9:29 am
Fuckin shit. Plastic pistons. Two popped out. Two are stuck. Probably why i can't stop. Now what...ideas? Ordered ss replacement pistons.
Interesting, how many use plastic pistons nowadays? Seems to be not too good in a place which theoretically can become quite hot..
yeah.
http://www.rideformula.com/
Post
by Laoch » Sat Mar 24, 2018 1:23 pm
New ss boron coated something or other. It was harder getting the new ones pressed in. All bled. Now to test, bleed and repeat. Hopefully I will have front brakes.
Nobody
- DAMN Poohba
Post
by Nobody » Sat Mar 24, 2018 1:35 pm
Laoch wrote: ↑Sat Mar 24, 2018 1:23 pm
note to myself: "If you want a KTM, don't buy a Freeride"
Post
by juddspaintballs » Sat Mar 24, 2018 2:05 pm
Bruce, snag a 60cc syringe with a blunt tip, 1/4" aquarium tubing, and brake fluid. Put the tubing on the syringe and attach it to the bleeder. Open bleeder and push fluid up into the master cylinder until no more bubbles. Air bubbles like to rise and this method works great on bikes.
Post
by Laoch » Sat Mar 24, 2018 2:26 pm
Jed-
I think I did my clutch that wayu. So fsr so good.
Janis-
Post
by J&J » Sat Mar 24, 2018 4:11 pm
“Phenolic pistons reduce heat transfer into the brake fluid, resist corrosion that could cause caliper binding and are lightweight.”
That’s what the “smart guys” say. Most vehicles have them now.
I’m not a sart guy though, just sayin....
And I’ve seen them break if not pushed back evenly.
