Fixing XR650L
Re: Fixing XR650L
What plate? There is a piece of sheet metal propped up on an old coffee can to help direct the blower air out into the room. Maybe your talking about the pipe adapter? Originally was a fireplace insert & I didn't need an 8" flue.
The copper tubing was an experiment, used to be hooked to a bucket that I put used motor oil in which dripped on the wood. Made more heat but was a pain in the ass to regulate.
Re: Fixing XR650L
Sounds like somebody is making "shine"J&J wrote: ↑Sun Feb 11, 2018 8:23 amWhat plate? There is a piece of sheet metal propped up on an old coffee can to help direct the blower air out into the room. Maybe your talking about the pipe adapter? Originally was a fireplace insert & I didn't need an 8" flue.
Re: Fixing XR650L
that is EXACTLY what I was thinking!
Re: Fixing XR650L
That’s just what Pat was hoping!
You guys all think alike.
Re: Fixing XR650L
Glenduro
Been there, Done that , and bought the replacement parts
Honda CRF450X
Honda XR650L
Honda CRF450X
Honda XR650L
Re: Fixing XR650L
Ok you guys wanted some pictures?
Well I was so anxious to see the inside I neglected to clean the frame & wire harness above the motor before I started... I know better
Now where was I?
Now where was I?
Re: Fixing XR650L
The cam marks should be level with head while at TDC. There not, need chain...
And I'm not liking this cam lobe so much, not the greatest picture but the shiny one is starting to pit...
Re: Fixing XR650L
Pitting cams is why I sold mine with 30,000 miles on it. The starter and ecu failed on the next guy, but the motor still runs...J&J wrote:The cam marks should be level with head while at TDC. There not, need chain...
Re: Fixing XR650L
This one has 13,000 miles....
The new piston is 2mm larger. Max bore on stock sleeve.
And the deck is .68mm taller.
I'm taking out a good usable Weisco forged 101mm 8.7:1 cr which is the first oversize and up from stock 8.3:1 cr. An improvement over stock.
Anybody want it let me know. You would need rings & new wrist pin clips would be a good idea.
That's all for now I'm going to research cams. I hope to pull the head apart within the next week, send my cylinder out to get bored & send my exhaust out for ceramic coating.
Users browsing this forum: Bing [Bot] and 31 guests
