Fixing XR650L
Re: Fixing XR650L
Post by Wingfixer »
Love the stove Jay! What's the plate and piping do?
Re: Fixing XR650L
Post by J&J »
What plate? There is a piece of sheet metal propped up on an old coffee can to help direct the blower air out into the room. Maybe your talking about the pipe adapter? Originally was a fireplace insert & I didn't need an 8" flue.
The copper tubing was an experiment, used to be hooked to a bucket that I put used motor oil in which dripped on the wood. Made more heat but was a pain in the ass to regulate.
Re: Fixing XR650L
J&J wrote: Sun Feb 11, 2018 8:23 am What plate? There is a piece of sheet metal propped up on an old coffee can to help direct the blower air out into the room. Maybe your talking about the pipe adapter? Originally was a fireplace insert & I didn't need an 8" flue.
Sounds like somebody is making "shine" :shrug:
Re: Fixing XR650L
Laoch wrote: Sun Feb 11, 2018 9:08 am
J&J wrote: Sun Feb 11, 2018 8:23 am The copper tubing was an experiment, used to be hooked to a bucket that I put used motor oil in which dripped on the wood. Made more heat but was a pain in the ass to regulate.
that is EXACTLY what I was thinking! :lol2:
Re: Fixing XR650L
Post by J&J »
:killingme: That’s just what Pat was hoping!
You guys all think alike.
Glenduro
Re: Fixing XR650L
Post by Glenduro »
Rut Row wrote: Fri Feb 09, 2018 7:00 pm
Wingfixer wrote: Fri Feb 09, 2018 6:55 pm Cool! Very clean!
It's still a Honda :barf:
Even John Wayne rides a honda.
:peep:
Glenduro
Been there, Done that , and bought the replacement parts
Honda CRF450X
Honda XR650L
Re: Fixing XR650L
Post by J&J »
Ok you guys wanted some pictures?
Well I was so anxious to see the inside I neglected to clean the frame & wire harness above the motor before I started... I know better :dry:
Now where was I?
Re: Fixing XR650L
Post by J&J »
The cam marks should be level with head while at TDC. There not, need chain...
And I'm not liking this cam lobe so much, not the greatest picture but the shiny one is starting to pit...
zjcoombs
Re: Fixing XR650L
Post by zjcoombs »
J&J wrote:The cam marks should be level with head while at TDC. There not, need chain...
Pitting cams is why I sold mine with 30,000 miles on it. The starter and ecu failed on the next guy, but the motor still runs...
Re: Fixing XR650L
Post by J&J »
This one has 13,000 miles....
The new piston is 2mm larger. Max bore on stock sleeve.
And the deck is .68mm taller.
I'm taking out a good usable Weisco forged 101mm 8.7:1 cr which is the first oversize and up from stock 8.3:1 cr. An improvement over stock.
Anybody want it let me know. You would need rings & new wrist pin clips would be a good idea.
That's all for now I'm going to research cams. I hope to pull the head apart within the next week, send my cylinder out to get bored & send my exhaust out for ceramic coating.
