Hold the phone...Ken....
...did you get another Katoom?
I think this is now in your sig---->2011 KTM 450 Xc-W Six Days (plated)
Re: Hold the phone...Ken....
when I get home tonight I'll walk out into the garage and check
I really didn't want it ... ... well you f*ckers were going to let it get away! only had 596 miles on it! It's all YOUR fault! I did it to protect YOUR reputations - sacrificed myself for you
Some gratitude I get
it sat for a long time and needs some TLC. Got a new battery in it but it still wants to stay in a comma. Will pull the plug this weekend and check for spark.
Don't look for me to get out until late this fall if at all. Most likely next year.
that would be a bitch pushing the bike!
More likely old fuel, dump the tank, put in fresh fuel then let a little fresh in the carb bowl then pull the bowl drain to flush it out. Might need to clean the carb. You could test for fuel issues with a little shot of starting fluid just to see if it wants to light off.
already tried that and didn't even sputter
Users browsing this forum: Majestic-12 [Bot] and 19 guests
