Why I don't work on carbs
- anotherguy
Re: Why I don't work on carbs
The blue needle in the JD kit is a half step richer than the red. The colors indicate hot/cold.
Then it must be the blue needle I put in....they say that memory is the third thing to go...
- anotherguy
Yeah a JD kitted FCR is as close to EFI you can get. Throttle response is surprising.
Runs much better at higher rpm's and is a bit more snappy.
Now to fix the stator issue
Related to the JIS screwdrivers Motion Pro now has some JIS bits in their product line up: 08-0576 (JIS 1), 08-0577 (JIS 2), and 08-0578 (JIS 3) plus a T handle set with 3 bits 08-0557. I've got screwdrivers but don't carry them on the bike. The bits will be better since they don't add much bulk and I already carry a bit driver.
http://www.motionpro.com/search?q=JIS+cross+head
I recently took carb off of my IT175 apart ...ooops
Luckily I have two and I think I'm good. Start and run test later.
Users browsing this forum: No registered users and 4 guests
