I have been having problems with the server running out of resources and giving errors. It is better but I'm still getting some periodically. Please report any you get to me at
ken@kyler.com.
DAMN maintenance and repair thread; including Farkle Fests!
Post
by J&J » Mon Jun 01, 2015 5:28 pm
thetable wrote:First, start with the right screwdriver. These are not your father's phillips screws. Get yourself a nice set of JIS screwdrivers. I've been really happy with the Vessel drivers.
A little more information for anyone that doesn't know;
JIS stands for Japanese industrial standard
Post
by Laoch » Tue Jun 02, 2015 6:25 am
Good call on the tools. I usually don't skimp on getting the right tool for the job...I never thought of "real" screwdrivers.
Waiting on parts.....
Mike- you talking about a WR? Yami blue?
BillyGoat
Post
by BillyGoat » Tue Jun 02, 2015 8:07 am
Go to the DRZ400 forum at Thumpertalk for all the advice for a DRZ that you could ever want. For jetting for the 400, go to the Jetting forum @ Thumpertalk and do a search for DRZ400 and you're answer will be there. The KLZ and DRZ are the same. Your answer will probably be best from Eddie Sisneros.
thetable
Post
by thetable » Tue Jun 02, 2015 8:33 am
J&J wrote:JIS stands for Japanese industrial standard
If I were smarter, I'd have put up a pic.
Pro-tip, the JIS screws usually have a little dot on the head. Lazy-tip, JIS drivers work just fine in plain old freedom phillips screws too.
You'll also see that the screw you were trying to use a Phillips #1 in, takes a JIS #2, and that JIS driver will most likely even remove the already damaged screws. I've seen my share of buggered up brake reservoir screws that came right off with the right driver.
Post
by Laoch » Tue Jun 02, 2015 8:51 am
BTDT too.
Post
by Laoch » Tue Jun 02, 2015 9:12 am
BillyGoat wrote:Go to the DRZ400 forum at Thumpertalk for all the advice for a DRZ that you could ever want. For jetting for the 400, go to the Jetting forum @ Thumpertalk and do a search for DRZ400 and you're answer will be there. The KLZ and DRZ are the same. Your answer will probably be best from Eddie Sisneros.
Good call.
Post
by Marylander » Tue Jun 02, 2015 10:58 am
What size JIS screwdrivers are needed for typical bike work? I've stripped my share of screws on carbs, brake reservoirs, you name it. ;)
thetable
Post
by thetable » Tue Jun 02, 2015 12:56 pm
Marylander wrote:What size JIS screwdrivers are needed for typical bike work? I've stripped my share of screws on carbs, brake reservoirs, you name it. ;)
95% of what I've encountered is the +P2 (I think that's the right nomenclature), but I ordered the set of 1, 2, and 3.
http://www.vesseltools.com/hand-tools/s ... e.tpl.html Pretty sure I actually ordered mine from McMaster.
Post
by Marylander » Tue Jun 02, 2015 4:20 pm
Cool, thanks. Going in search of a deal on 'em now.
BillyGoat
Post
by BillyGoat » Tue Jun 02, 2015 6:34 pm
I don't know why everyone is talking about JIS screws etc...just go get some nice Cap-head hex key type screws. They work best and will never be a problem to remove. Plus they'll be $1 instead of $50 for the screwdrivers. Just my uninformed opinion that's all.
Users browsing this forum: Bing [Bot] and 24 guests
