Drz front ends
Drz front ends
Is there a difference between drz400s and drz400e front ends? I know the SM has inverted forks. I'm looking to have a complete front end to swap between street and dual sport and have a line on an E and want to make sure that it'll work, with speedo.
Sent from my SM-G960U using Tapatalk
Re: Drz front ends
Do you ever get over to Thumpertalk.com?
They have some very knowledgable guys
Re: Drz front ends
Looks like "the only difference is the E forks from '00 and '01 are better than the S" (the forks I'm looking at are from 01).
https://thumpertalk.com/forums/topic/84 ... 00e-forks/
Re: Drz front ends
phoo wrote: ↑Mon Jul 15, 2019 3:47 pmLooks like "the only difference is the E forks from '00 and '01 are better than the S" (the forks I'm looking at are from 01).
I don't get on Thumpertalk very often. But when I need good technical info about fixing stuff its often where I go. I know the DRZ and DR forums have some great guys, super knowledgeable
Re: Drz front ends
OOPS! please delete this post.....
'06 VTX1300r
'06 VTX1300r
Re: Drz front ends
To my knowledge there is no difference as for as fitment from start of production through today. There are some valving and spring rate changes from E to S, if they have never been redone for the preference of the owner....You should look for the '05 up though they did update the front end but the fork tubes will still interchange.
'06 VTX1300r
'06 VTX1300r
Re: Drz front ends
See if frames and neck bearings are same part numbers on bikebeandit microfiche would be my suggestion.
Re: Drz front ends
I should have posted an update, but I ended up buying it. So I guess I'll just find out from experience whether or not it fits to my liking. ;-)
Users browsing this forum: No registered users and 31 guests
