Drz front ends
Drz front ends
Post by phoo » Mon Jul 15, 2019 1:57 pm
Is there a difference between drz400s and drz400e front ends? I know the SM has inverted forks. I'm looking to have a complete front end to swap between street and dual sport and have a line on an E and want to make sure that it'll work, with speedo.
Patrick
Sent from my SM-G960U using Tapatalk
2008 (?) KLX250S - getting it on the road someday
Re: Drz front ends
Post by Bucho » Mon Jul 15, 2019 2:22 pm
Do you ever get over to Thumpertalk.com?
They have some very knowledgable guys
Re: Drz front ends
Post by phoo » Mon Jul 15, 2019 3:47 pm
Looks like "the only difference is the E forks from '00 and '01 are better than the S" (the forks I'm looking at are from 01).
https://thumpertalk.com/forums/topic/84 ... 00e-forks/
Re: Drz front ends
Post by Bucho » Mon Jul 15, 2019 4:51 pm
I don't get on Thumpertalk very often. But when I need good technical info about fixing stuff its often where I go. I know the DRZ and DR forums have some great guys, super knowledgeable
Damage Inc.
Re: Drz front ends
Post by Damage Inc. » Wed Jul 17, 2019 2:30 pm
OOPS! please delete this post..... :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers:
'06 VTX1300r
Damage Inc.
Re: Drz front ends
Post by Damage Inc. » Wed Jul 17, 2019 2:36 pm
To my knowledge there is no difference as for as fitment from start of production through today. There are some valving and spring rate changes from E to S, if they have never been redone for the preference of the owner....You should look for the '05 up though they did update the front end but the fork tubes will still interchange.
'06 VTX1300r
zjcoombs
Re: Drz front ends
Post by zjcoombs » Sat Jul 27, 2019 11:39 am
See if frames and neck bearings are same part numbers on bikebeandit microfiche would be my suggestion.
Re: Drz front ends
Post by phoo » Sat Jul 27, 2019 12:20 pm
I should have posted an update, but I ended up buying it. So I guess I'll just find out from experience whether or not it fits to my liking. ;-)
