EXC rear wheel bearing replacement question
mdubya
Post by mdubya »
I pulled the bearings. They were almost too easy to extract. The question is, there is a circlip retainer on the left side, but there was no circlip retainer on the right side; should there be a circlip on the rh side too?
Re: EXC rear wheel bearing replacement question
mdubya wrote:I pulled the bearings. They were almost too easy to extract. The question is, there is a circlip retainer on the left side, but there was no circlip retainer on the right side; should there be a circlip on the rh side too?
the fiche at BikeBandit does not show a circlip on the other side
so get those bearings and over to RRob's tomorrow!
mdubya
Post by mdubya »
Yep. I looked a little harder and there is a new circlip in the rebuild kit and only the one side has the recess for the circlip. Botton line: the bike is back together with fresh bearings, got 'er started and warmed up to an easy idle.
So now I have the chain adjusted super loose. With the rear at full extension on the stand, I have four fingers of slack just behind the chain block. Does that sound about right? Too loose? Too tight?
Anyways, it will be good for tomorrow.
:roost:
Let's see how the rider is.
gtop
Post by gtop »
The chain can never be too loose on a KTM :thumbup: .
I made a "feeler gauge" that works well - I'll show you tomorrow :hi5:
