Fighting with the 300
Hare
Re: Fighting with the 300
Post by Hare » Fri Nov 18, 2016 5:35 pm
the hub spacer is a wear item too. same with wheel spacers and even the axle too although the axle will last a while.
There is a lot to be said for the complete aftermarket kit that has the bearings, hub spacer, wheel spacers, bearing and seals (if applies) all in one. make sure to get the correct set for the axle size you have, if that don't fix it something is wrong with the hub or its the a hub off another bike.
I would put my money on the hub spacer being too long or someone beat a bearing in wrong and it cant bottom out.
I wouldn't run it, if the sprocket is not lined up you can cause all kind of problems you don't need.
Hare
Post by Hare » Fri Nov 18, 2016 5:36 pm
Damage Inc. wrote:Step back and start over..
Completely disassemble all the wheel bearings look at the hub and make sure no trash got on to the seating area inside. I've seen where people have forced a bearing in and caused the aluminum to scrape off and deposit on the seat. If this has the inner sleeve/spacer, then build it without the hub. Take the axle bolt and feed it though the swing arm-spacer-bearing-center spacer-bearing-spacer. And see if it fits right. If so then somethings up with the hub. if not then something up with the bearings or the spacers or possibly the swing arm. How does the inside of the arm look and the caliper slide thingy. Not often but if it was run for a while with a loose wheel then they could be damaged. KTM didn't do somekindabullshit with selectable spacers did they?
yeah what he said! :hi5:
Post by Laoch » Sat Nov 19, 2016 4:16 pm
I'm going to order the upgrade kit and go from there.
I did take everything apart,again, and it went together like it was supposed to. I even popped off the brake caliper to get a better look at things.
I did a little grinder action to one spacer and used one of the original spacers, which really just looks like a fat washer. Tightened it down without a hitch, took a few measurements and everything lined up. Little test ride and all seemed well, so we said, "fuk it" and ran it hard for a couple hours today. It'll work for now and until the snow flies, then we'll put it in the garage and tear the whole bike down.
I still don't really know why things were off. How many times have you pulled rear wheel and then all of a sudden one won't go back on :shrug:
Hey, it's a $900 bike, I'm not complaining :deal:
My son and SIL thing it's "beastly" :lol2: They can't keep the front tire on the ground.
Post by Laoch » Wed Jan 11, 2017 7:41 am
Naked pictures
Got it tore down and back together. No issues with rear hub, still gonna get custom kit to put on. Two other things remain, kick start bolt broke off and ez out broke off in shaft :lol2: It works.
And is there supposed to be a lower chain roller? I added one (bolt was cut down after pic taken) where it looked like it was supposed to go.
Damage Inc.
Post by Damage Inc. » Wed Jan 11, 2017 10:44 am
I don't think my '00 had one when I got it....The KTM parts list does shows one.
part numbers
52303053100 35mm roller
0625006087 bearing 2 needed
7400302100 bushing
0015080353 bolt
54310086200 lock nut
I think I used an Allballs kit off ebay
'06 VTX1300r
Post by juddspaintballs » Wed Jan 11, 2017 4:55 pm
The 250 EXC I had and my 450 EXC don't have one
Post by Laoch » Sun Feb 26, 2017 5:12 pm
Replaced the PDS joints on that sucker today......what a chore :deal:
The original was totally fried, worn through the bearing into the swingarm. That's why it was clunking.
Post by juddspaintballs » Sun Feb 26, 2017 8:01 pm
Lookup "Morgans Tool"
Post by Laoch » Mon Feb 27, 2017 6:44 am
Yeah I did. Kinda made my own with sockets and large bolt/nuts etc. Worked like a charm.
Getting, or beating the old one out was the issue. Also I'm lazy and left swing arm on bike with tire on :lol2:
Actually went okay, but it's some work.
Post by juddspaintballs » Mon Feb 27, 2017 5:35 pm
I've done it on the bike before. It's a pain, but it works. Invest in the neoprene sock for the lower heim joint to cover it and that joint will last a long time. You could also cut up an old front tube and make a cover for it.
