Replacing fork oil, WP inverted forks (ktm)
restukey
Re: Replacing fork oil, WP inverted forks (ktm)
Post by restukey » Wed Sep 17, 2014 7:47 pm
That looks like the older style open cartridge forks. The oil is not set by volume. The spring normally has some pressure on the preload spacer, but there is a washer like cup that it sits on that can go askew. Here is a video on how to set the oil level. It is really easy to get it wrong, because of trapped air.
Post by Boom Boom » Wed Sep 17, 2014 8:40 pm
restukey wrote:That looks like the older style open cartridge forks. The oil is not set by volume. The spring normally has some pressure on the preload spacer, but there is a washer like cup that it sits on that can go askew. Here is a video on how to set the oil level. It is really easy to get it wrong, because of trapped air.
Winner...Winner...Chicken dinner
2019 TRS 300 RR
2014 KTM 250 xcf-w
1986 Yamaha TY 350
1985 Yamaha TY 350
aka "That Guy"
Post by phoo » Thu Sep 18, 2014 2:13 pm
That's the video I used to learn what to do. I set the height with a depth gauge, but my special oil height tool finally arrived on Tuesday so I can do it faster and easier next time.
I twisted the spring and now it makes very little noise, but I swear it used to make none at all. It could just be that I'm hyper sensitive to it since I'm specifically listening for it. I'm going to leave work early today to get back to this and see if I can finally get everything feeling right when it all goes back together.
aka "That Guy"
Post by phoo » Sun Sep 21, 2014 3:03 pm
Okay, something else is going on, too, but am I correct in assuming that if the spring doesn't just slide on like in this video (link goes right to the part I'm talking about) -- that the spring is too small of diameter or the plastic inner guide is too big? When I first opened up the forks, the spring was so hard to pull up that I actually thought it was fastened on somehow. And to get it back on, I need to thread it on by jamming a wrench onto that top nut then twisting the spring, using the wrench as a "thread." And now that I know what I'm hearing, I took the other fork off and can hear the spring binding on that black plastic piece when I compress it by hand.
So before I complain, am I correct that this isn't right? And yes, I realize it's been like this for over a year so I guess it's not terribly bad. I just want it to be right, and maybe this other issue I seem to be having at the moment would go away in the process. :think:
bonehead
Post by bonehead » Sun Sep 21, 2014 6:18 pm
I asked Sam to look at this thread. He will know. Since going to mechanics school he has become a snob. Dad isn't even worthy to spoon off a tire let alone check the pressure, :poser:
restukey
Post by restukey » Wed Sep 24, 2014 1:26 pm
Ain't youtube great! Let me know if you need springs? I might have something in my stash?
aka "That Guy"
Post by phoo » Thu Sep 25, 2014 8:20 am
Thanks for the link. I figured you could just grind / sand it thinner. I like how he didn't pull any punches talking about the other suspension shop.
