Replacing fork oil, WP inverted forks (ktm)
aka "That Guy"
Post by phoo » Sun Sep 14, 2014 5:26 pm
Is it normal for the spring to be so tight against the plastic thing inside the fork? It isn't on videos I've seen. Now that I've put it back together, I can hear the spring rubbing, which I assume isn't normal.
I think I've fixed the leak, but now it doesn't seem to be right, which is odd given that all I did was take the cap off, dump the oil, and put in fresh oil (plus use a "seal mate").
Any hints?
Patrick
BigBird
Re: Replacing fork oil, WP inverted forks (ktm)
Post by BigBird » Sun Sep 14, 2014 11:07 pm
I think the nominal preload on the springs is ~5MM (by adding or removing plastic/nylon spacers)
Although spring rubbing is not ideal doubt it really matters much.
GL1800A - KTM 525 EXC - KTM 200 XCW - KTM Freeride 250
Beta Evo 200 - Yamaha WR250R
Lots of Off-road & Road Tandem & Single Bicycles
aka "That Guy"
Post by phoo » Mon Sep 15, 2014 7:41 am
Thanks, Sam. There is the 5mm spacer. I'm going to see if everything is seated correctly.
Patrick
anotherguy
Post by anotherguy » Mon Sep 15, 2014 9:12 am
If you didn't remove the cartridge and pump it dry then filled with the recommended amount of oil you did it wrong. You need to pump the cartridge out or the remaining oil in it will overfill and contaminate the fresh oil. To disassemble you need a spring compressor. Look like this and is about $150 or so. There are cheaper versions but they........well they suck.
And that plastic sleeve is sacrificial it keeps the spring from rubbing against the inside of the slider and putting lots of aluminum shavings in the oil.
BillyGoat
Post by BillyGoat » Mon Sep 15, 2014 11:31 am
On the other hand, 1/2 fresh oil is better than no fresh oil.
Post by Rut Row » Mon Sep 15, 2014 12:18 pm
BillyGoat wrote:On the other hand, 1/2 fresh oil is better than no fresh oil.
Oil is highly overrated. Just run them dry! :harhar:
aka "That Guy"
Post by phoo » Mon Sep 15, 2014 3:59 pm
Bingo!
I did dump and pump and dump (bow chicka bow wow) so it should be pretty clean, but the oil was only a year old, anyway. My motivator was cleaning the fork seal and replacing the oil that dumped all over Michaux.
anotherguy
Post by anotherguy » Mon Sep 15, 2014 5:08 pm
OK it's yer money.
Time doesn't matter what kills suspension fluid is being forced through those little holes at extreme pressures repeatedly. Lots of heat and shear.
Post by Rut Row » Mon Sep 15, 2014 6:35 pm
anotherguy wrote:Time doesn't matter what kills suspension fluid is being forced through those little holes at extreme pressures repeatedly. Lots of heat and shear.
and that's what SHE said! :harhar:
Bork
Post by Bork » Mon Sep 15, 2014 10:20 pm
"(bow chicka bow wow)" :poser: :poser: :poser:
