Help me out again- bike has 14/45---I want lower, or slow, ST riding type gearing as opposed to WFO MX type riding.
So up the rear to 50 or 52 (stock) and maybe go 13 on CS.
Right?
Sprockets-again
Sprockets-again
Re: Sprockets-again
Right, drop 1 tooth on the cs is the same as adding 3 to the rear. So with what you have on the rear now would be like a 48 tooth with a 13 cs. You might be able to go as low as a 12 tooth cs which would make the rear a 51.
2012 Husky WR 125
2009 Husky TE 310
2001 Harley FLHR
2009 Husky TE 310
2001 Harley FLHR
Re: Sprockets-again
I think you would be happy with a 13/48 combo.
A 12 on the front can wear the chain slider fast.
Re: Sprockets-again
I thought there might be a problem with the 12 but wasn't sure of the reason. I thought I was told it was chain wear. It still didn't keep me from using one but that was before chain sliders.Boom Boom wrote:I think you would be happy with a 13/48 combo.
2012 Husky WR 125
2009 Husky TE 310
2001 Harley FLHR
2009 Husky TE 310
2001 Harley FLHR
Re: Sprockets-again
Try 13-45 first. That will be cheapest and wont require a new chain. When I went from 15-45 to 13-48, I needed a new chain with 2 more links. so that big $$$. Don't go to a 12 unless you know that it wont chew up the swingarm slider.
Re: Sprockets-again
OK....I ordered a complete stock set up that way I know it will fit.
And I also ordered a 13t CS. The current setup with the 45 rear looks like it pushes the chain into the rear chain guide pretty good and the chain is also shorter.
I'll go with that for a while
Re: Sprockets-again
Taylor wrote:I thought there might be a problem with the 12 but wasn't sure of the reason. I thought I was told it was chain wear. It still didn't keep me from using one but that was before chain sliders.Boom Boom wrote:I think you would be happy with a 13/48 combo.
In addition to the chain slider and swingarm clearance when swingarm is compressed or extended, a 12 tooth counter sprocket is a small diameter so it makes the chain "tighter" around the sprocket and does indeed wear chains faster, but to the average rider, probably would never know. 13 is usually the smallest I have ever had to go to get it right!
Users browsing this forum: smdub and 45 guests
