Acetone and ATFBillyGoat wrote:For releasing the screw, didn't I see in this forum that mineral spirits + brake fluid (or something like that) beat Liquid Wrench? Also I like to put the screwdriver in the slot then hit it sharply with a hammer to loosen it before trying to turn the screw. What's even better is if you have a manual impact wrench driver with a standard bit on the end. It's like an air impact wrench but it's manual and uses a hammer hit to both do the impact and to turn the bit.
Stripped Idle/Mixture Screw
- Longboardr
Re: Stripped Idle/Mixture Screw
- anotherguy
Use a good penetrating oil ( I like Kroil) of your choice. Leave overnight. Dip tip of screwdriver in valve lapping compound then try to unscrew. Carb bodies are very easy to destroy so go easy. It's not likely corrosion seizing the screw probably the wonderful gunk left behind when gas evaporates.
Alot of the time it is corrosion due to moisture and dissimilar metals.
'06 VTX1300r
'06 VTX1300r
You know, before I knew better, Sears used to sell a liquid to increase the turning power of screwdrivers. I'll bet it was way overpriced lapping fluid.
I have a purpose modified extractor for that, I'll pick it up from you on Sunday, return it Monday.
You da MAN!Wingfixer wrote:I have a purpose modified extractor for that, I'll pick it up from you on Sunday, return it Monday.
I recently used a reverse cut drill bit and extractor to get one out of my BW80 carb.
Husky TE 250
KLR 650
Honda Reflex (not the scooter)
Yamaha RD350 (project)
KLR 650
