DAMN Riders Coronavirus Precautions
Posted: Thu Mar 19, 2020 6:53 am
In order to comply with Federal and State guidelines for social distancing, DAMN Riders will limit the number of concurrent online connections to 10 or less. Please also follow these precautions:
- Please use a remote keyboard and stay at least 10' away from your computer.
- Regularly and thoroughly clean your hands with an alcohol-based hand rub. Everclear works well and can also disinfect your mouth and throat.
- If you must go out, use a face mask. If none are available, try using your motorcycle air filter. Make sure you use a high quality filter oil and seal the edges with a water-resistant grease.
