Receiver-Mount Motorcycle Carrier
Damage Inc.
Post by Damage Inc. » Mon May 14, 2018 3:31 pm
Anybody have a Receiver-Mount Motorcycle Carrier for loan/rent or sale?
'06 VTX1300r
Re: Receiver-Mount Motorcycle Carrier
Post by juddspaintballs » Mon May 14, 2018 4:19 pm
Contact Gene
Three Zero One 356 Two 7 Five One
He has one for sale cheap, I'm sure. It's a HF carrier I fixed so it's actually strong.
Bork
Post by Bork » Thu May 17, 2018 4:45 pm
Contact Gene
How did you make it stronger? I'm thinking of getting one. I dont like the looks of the thin 2" aluminum square channel over the the 2"square steel tongue. The see-saw effect would crack/split it?
1997 xr600 plated
Post by juddspaintballs » Thu May 17, 2018 8:18 pm
The 2" square tube is extremely thin and it wallowed out the hitch pin hole after just a couple uses. The aluminum bracket that holds the horizontal tray to the square tube is also prone to failure. I replaced the 2" square tube with a thicker walled SS tube (only because that hunk of SS was cheap) and used 2" angle iron to hold it on with proper bolts. I also used a piece of 1-1/4" square bolted under the carrier about where the handlebars would be directly above it for easier tie-down of the bike.
Give Gene a call. Since I built him a massive 3'x7' platform that he's using on the back of his truck, he doesn't need the HF carrier anymore.
Bork
Post by Bork » Thu May 17, 2018 9:04 pm
OK, thanks for the info but didn't want to buy out from under "Damage inc" .
Also looks like he might be pretty far east?, according to his phone #. I'm closer to Frostburg, probably not worth the drive. Unless someone wants to drag to Mountain Ridge to meet me.
1997 xr600 plated
Post by juddspaintballs » Thu May 17, 2018 9:07 pm
He's Brunswick.
Damage Inc.
Post by Damage Inc. » Fri May 18, 2018 5:40 am
If you want it go for it he's too far away from me to be worth it.
'06 VTX1300r
Bork
Post by Bork » Sat May 19, 2018 7:53 pm
Thank you. I made contact.
1997 xr600 plated
Bork
Post by Bork » Sun May 27, 2018 8:36 pm
Done deal, Thank you!
1997 xr600 plated
